Device Info Bubble Mobile
This plugin gives you device info, locale, and timezone-aware date states — with optional live updates! It’s perfect for logging, user profiling, regional settings, or displaying timezone-adjusted con
Plugin link: Device info Bubble Mobile Plugin | Bubble
:brain: What This Plugin Does
Detects the user’s device type, OS version, and screen size
Detects user’s timezone automatically
Allows you to define a custom timezone (your “platform timezone”)
Provides the current time in both zones
Calculates how much time remains until midnight in each timezone
Can run on a set interval for real-time updates
:gear: Features
:white_check_mark: 1. User Timezone Date
The plugin automatically figures out what timezone the user’s device is in and publishes the current date/time for that timezone.
You can use this in Bubble to:
Display a clock based on the user’s location
Tag log entries with localized time
Send correct timestamps to your backend
:globe_showing_europe_africa: 2. Platform Timezone Date
You can provide your own custom timezone (e.g. Europe/Brussels) to get the current time there. This is useful if:
Your backend/server runs in a fixed timezone
You’re showing event times in a specific region
You want to compare two timezones (user vs platform)
This field supports all IANA timezones like America/New_York, Asia/Tokyo, etc.
:counterclockwise_arrows_button: 3. Live Realtime Updates (Optional)
Want the date/time states to update continuously?
Turn on the realtime mode and optionally configure the refresh rate.
so awesome just tried it and worked fantastic!
Thanks Lukas! Appreciate the feedback.
