Generate shipping labels - video tutorial - Jan-26 update
Just released a new video tutorial on generating PDFs of shipping labels with DocuPotion:
A bit different to some of the other video guides I’ve posted as the shipping label is designed using the DocuPotion template editor (rather than designing it in a separate page of your Bubble app):
New Repeating Element component - January-26 update
An update for DocuPotion users designing their PDFs using the template editor: we recently released a new Repeating Element component.
It’s quite similar to the repeating group you’ll be familiar with from Bubble. The repeating element let’s you display a list of items in a grid layout.
The new GET Templates endpoint allows you to programmatically access all templates you created in the DocuPotion template editor. Here’s a sample response:
Alex, any easy way to shrink to page for a page (within a bunch of other pages)? Or to have Create PDF generate different size pages that can then be printed to shrink to fit?
Once you’ve created your template via the DocuPotion dashboard, you can Generate PDFs of it from your Bubble app using our plugin (using the ‘Create PDF from Template’ action).
Other cool bits
Provide sample data - provide sample data and the AI will automatically include {{merge_fields}} that match your data schema
Follow-up edits - simply chat with the AI to make edits after the initial generation
Multi-page documents - build multi-page contracts, proposals and other docs with neat page breaks
Image uploads - drop in your own images and have them embedded directly into the template
Try it out
You can try out the AI-powered editor in the templates section of your DocuPotion dashboard.
How to create a reusable template from an existing PDF - June-26 update
Just wanted to highlight a new feature I added to the DocuPotion AI template generator recently. Let’s say you have an existing, static PDF file, like this property brochure PDF:
You can either add in your own sample data for the {{merge_fields}}, or let DocuPotion do it for you. In this example, we’ll let DocuPotion add the appropriate sample data.
DocuPotion has added {{merge_fields}} for the agent name and contact details. These are going to be the same every time, so we can ask DocuPotion to use static values for these fields via the chat pane.
Click on the Publish button to make sure these changes are go live. You can now create PDFs of your reusable template in your Bubble app using the Create PDF from Template action that comes with the DocuPotion plugin.
See this section of the DocuPotion docs for full details on generating PDFs from templates in Bubble with DocuPotion.
Bonus tip
The With data tab in the DocuPotion editor gives a pretty good preview of how your template will look with actual data, but you can also download an actual PDF file by clicking on the Download Sample button.
New video tutorial - creating detailed PDFs in Bubble with DocuPotion - June-26 update
Recently released a new video that covers all the basics of using DocuPotion.
If you’re an existing user, there won’t be too much new here, but if you’re thinking of trying it out then I would recommend starting with this video (it has the new properties editor which makes it bit easier to follow).
Topics covered include:
Designing your PDFs using a template approach
One-page vs. multi-page PDFs
Adding headers and footers
Including / excluding various parts of your PDF based on user role
Random side note: I recently started putting my face on video thumbnails as I heard this increases the % of people that click through to watch . This has not happened. Bad result for my ego.
