Drag & Drop releted issue(auto horizontal scroll))
I have an RG (currently 7 columns, 3 are showing 4 are findable in a horizontal scroll), and the user can make more.
The RG columns have a DROP area.
The cards in the column are dropable.
I can drag and drop the cards in the column to other columns, update the data, and make sure it stays in that column. WORKS! :slight_smile:
Now because there are so many columns, when a user picks a card in column 1 and wants to move it to the last column, the user can’t get there. Because when picking up the card the screen doesn’t ‘auto-scroll’ to the directing I want it to go.
Any suggestions on how to scroll, while having a draggable object?
I found the solution!
function enableScrollOnDrag() {
  var scrollThreshold_Left = 100;  // Constrain area to 100px from the left for scroll
  var scrollThreshold_Right = 100; // Constrain area to 100px from the right for scroll
  var scrollSpeed_Desktop = 6;
  var scrollSpeed_Mobile = 6;
  var isScrollingLeft = false;
  var isScrollingRight = false;
  function startScrolling(direction) {
    if (direction === 'left') {
      isScrollingLeft = true;
    } else if (direction === 'right') {
      isScrollingRight = true;
  function stopScrolling() {
  function continuousScroll() {
    var scrollElement = document.getElementById("your-scollable-container-id");
    if (scrollElement && (isScrollingLeft || isScrollingRight)) {
      if (isScrollingLeft) {
        scrollElement.scrollBy(-scrollSpeed_Desktop, 0); // Scroll left
      } else if (isScrollingRight) {
        scrollElement.scrollBy(scrollSpeed_Desktop, 0); // Scroll right
  document.addEventListener("mousemove", function (event) {
    var rect = scrollElement ? scrollElement.getBoundingClientRect() : null;
    if (rect && event.clientX >= rect.left && event.clientX <= rect.right && event.clientY >= rect.top && event.clientY <= rect.bottom) {
      if (event.clientX - rect.left < scrollThreshold_Left && !isScrollingLeft) {
        startScrolling('left');
      else if (rect.right - event.clientX < scrollThreshold_Right && !isScrollingRight) {
        startScrolling('right');
      else if (event.clientX >= rect.left + scrollThreshold_Left && event.clientX <= rect.right - scrollThreshold_Right) {
        stopScrolling();
    } else {
      stopScrolling();
  setInterval(continuousScroll, 20);
enableScrollOnDrag();
