Is it possible to set a checkbox in a repeatinggroup as “unchecked” using the given Dynamic status above?
The “Search for Order Items:count > 0” returns a “no” value. Shouldn’t this set the checkbox as unchecked?
For specific reasons, I cannot rely on refreshing the page to reset the checkboxes as “unchecked” by means of the Preset status option.
Can anyone suggest alternatives, in order to make the dynamic status uncheck the icon? Thanks
