I have a set of quizzes that I dynamically load onto a page based on a button a user clicks on a a different page.
On the quiz page, each question has radio choice options which are dynamically loaded based on the quiz that was selected. Each option has a score value, which I use to calculate quiz score and determine the result. So for example, if it’s a personality quiz, the score would be used to determine the personality type.
The questions for each quiz are loaded via a repeating group, and the radio buttons are loaded dynamically within the same.
My question is if there is an elegant solution to this? If I were to program this, I’d simply store the score for each selected item in a variable. Haven’t had much luck doing Bubble’s version of that (as a state). I also tried storing the radio results as a list of numbers to get the sum once the quiz was completed, but apparently lists cannot have the same value twice (the radio options are the same for each question, so repeats got ignored).
I’m currently using 1danielbaker’s solution, which technically works.
When I’ve done this in the past I’ve used a data type called sum that keeps adding every time a new budget(in your case) is added. You can also “do a search for…” the budget data type:sum (make sure the data is being stored as a number so you’re able to call up math functions)
Basically I’m creating a new thing to store each radio response, then storing the sum of those values on the thing that provides the survey “type.” The longest quiz is 13 questions - most are 5-10 questions. I tried running my workflow, and it was extremely slow. Hoping that I’ve just missed a more elegant and efficient way of doing this.
