Floating Group Vertical Issues
Hello, In my editor I am using a floating group as a dropdown for profile navigation and the floating group is making a big gap between the navbar and itself I have tried all options for the vertical reference dropdown but none seem to work. Please Help.
Why don’t you try using the GroupFocus element instead? You can anchor it to another element and then when the user clicks out of it, the GroupFocus closes automatically. This element will be much better and easier to use than the Floating Group element.
I will try that now thank you, and I will let you know how it goes.
Worked like a charm thank you for the help!
