GET API WITH BODY WONT WORK :( making me sad
Hey guys I am trying to hit an API endpoint and I need to pass through a body or json
but it seems bubble has no way to do so?
Any help?
probably something @tylerboodman knows…
Work around I found. I went on AWP API Gateway and basically changed the get into a post… now I am using a post as a get…
@TomIsCool
You can give this a try. It should work.
That does not allow a json body.
Only way to get it working is to change my aws api gateway from a get to a post… so I am now using POST as a GET. Really bad practice…
So bubble just decides that no body is allowed in GET? seems crazy
Just found this…
