Hello, I am new to bubble. I have created an app but the default header, footer, and signup elements are not showing. can anybody please guide attach is a
screenshot
I have the exact same problem.
It’s just not there.
Not loading any templates or anything. What am I missing?
Hi @lars.langenstueck
With the official launch of new responsive engine…
All the apps created after June 27 2022
Header / Footer / Signup reusable elements are removed…
Thanks so much! Found a thread that answered it as well!
But thanks for following up!
What would be the alternative to using this? creating new ones?
Hi @mmedv830 ![]()
Yes you have to create new ones ![]()
But it won’t be difficult to create new ones just learn new responsive engine
I believe It is hundred times easier than the old engine…
if you are just starting out please watch this video for brief overview of new responsive engine
