Header outside of Repeating Group not aligning
Hi All,
I created a Group (Row) sitting above a Repeating Group (RG) for column headers. However, I am struggling to align the text elements with the RG groups. I have been banging my forehead on my keyboard for hours and can’t seem to figure out what is causing it. I know it must be something simple and stupid I am doing… any pointers? :face_with_peeking_eye:
It’s got to do with that icon you have added on the extreme right (the 3 dots menu). It’s only in the row and not the header, which is why there’s an alignment issue. You can add that in the header and set it to not visible on page load, and it should work fine for you then
Hope this helps :smile:
Hahahaha! See! It was something stupid I was doing! :rofl:
No worries, happens to all of us. Glad you got the solution :slight_smile:
