I’m using this platform for the very first time and planning to build an invoice generator app where users can create an invoice and send it directly using this tool.
I started following some of the blog posts on your website but was unable to understand them
As I’m not a coder, kind of confused but kind of confident once understand can do the basic job(may still need some help).
Do you have a video about how to build an invoice generator using Bubble.io
Hope for a positive response from the community member or the support team.
Bubble support does not look at forum posts and then reply. For Bubble support to reply you need to send an email to them. Also, support does not answer questions on ‘how do I build my app’ and any questions about resources for guidance, they would likely just say ask on the forum.
You can check Bubble.io youtube channel, as well as search on Youtube, or Google and you might find something.
Yes, once you take the step of beginning to learn how Bubble works, then you’d be able to understand how to build the app you are attempting to build. Lots of videos on Bubble to start learning how to build on Bubble. I’d recommend starting there.
