Help configuring for mobile?
I love bubble and am super excited about building here, except I can only view a web version on my phone (iPhone5). I had a friend view it on a 6 and same deal.
I tried narrowing the screen down to 380. Nothing changed, Could not even tell if it took the fix or not. The standard desktop website view is all I can view on my phone.
Can anyone help with how I can optimize the experience for mobile?
The way it currently works is that you define a mobile version of your page that gets sent when the user is on a mobile device. At this stage that means you should build 2 versions of your page (but we’re working on responsiveness), but for the end user the experience will be seamless.
See https://bubble.io/reference#Elements.Page.mobile_page
Chrome browser has an awesome feature where you can view how your site looks on like 20 different devices. Right-click anywhere and then click inspect element, then in the upper left corner of the tray that pops up there’s a little mobile icon. Click that and you should be able to figure it out from there.
When I create the mobile version (which is effectively a different app), do I need to reconfigure the domain name settings etc for that version as well ? Or is there a better way to indicate that this is from mobile ? Thanks.
Not sure I’m following. It should be the same app, just a different page. What do you mean by “indicate that this is from mobile”?
