Help filter repeating group based on search results
I have a repeating group that searches for users. I have a filter on that page that users can modify to modify the search results in that repeating group. There is a dropdown for cities, a dropdown for services these users offer (four in total), a calendar start and end date to check for busy dates of these users, and a price start and end range for checking if the price matches. The problem is, I want the repeating group to filter if only one of these has been checked or if two have been checked to filter only for those two. How can I do that?
use the ignore empty constraints checkbox on the search constraints
I do, but I get only empty results for some reason…
check your data and ensure you have all the necessary data fields populated
