Help me develop a Template builder for document
I am looking for someone that could help me create a template builder like the one from Pandadoc or documint.
The main part :
  • create the drag and drop and the component
  • be able to manage the component on the page
  • integrate the variables
  • structure the database
  • make it responsive
    I have already the spec. If you have work on something similar, please provide the reference.
Hello @akoziol ,
I would be glad to assist you.
To discuss further in detail kindly reach me at garry@cisinlabs.com or Skype me: cis.garry
Looking forward for your response.
Thanks
Garry
Hello @akoziol
I have sent you a PM, Kindly check.
Best Regards,
Rishabh
