Help me finish my plugin
I almost finish my plugin , the last step is save canvas to database as a image link. But I got this error:
Konva error: Unable to get data URL. Failed to execute 'toDataURL' on 'HTMLCanvasElement': Tainted canvases may not be exported. For more info read https://konvajs.org/docs/posts/Tainted_Canvas.html.
This problem related to CORS issue but I don’t know how to apply to my plugin.
I used Konvajs library - https://konvajs.org
This is my plugin action code:
	var stage = instance.data.stage;
// function from https://konvajs.org/docs/data_and_serialization/High-Quality-Export.html#How-to-export-a-high-quality-image-from-a-stage
  var dataURL = stage.toDataURL({ pixelRatio: 3 });
	downloadURI(dataURL, 'stage.png');
    // function from https://stackoverflow.com/a/15832662/512042
      function downloadURI(uri, name) {
        var link = document.createElement('a');
        link.download = name;
        link.href = uri;
        document.body.appendChild(link);
        link.click();
        document.body.removeChild(link);
        delete link;
And finally, I still have know ideas how to save it to the next step in workflow.
a tainted image may be due to your image coming off of the S3 server and not the app server.
I just added a line of code to the images which I added to the canvas
var imageObj = new Image();
imageObj.crossOrigin = 'Anonymous';
imageObj.src = properties.shape_imageobj;
Now I have a problem with image exported. I don’t know how to save it to database. It’s now data:image/png;base64 format.
Try to find solution on this topic: Save Base64 encoded file to Bubble - #3 by JohnMark
But I have know ideas to apply it into my plugin
Hi @locnguyen1312, you need to use context.uploadContent
Example:
function uploadFile(err, url) {
  if (url) {
    console.log(url); // print the uploaded url to console
    instance.publishState('upload_file', url); // publish url to the element exposed states.
    instance.triggerEvent('file_uploaded'); // trigger event to do x workflows.
  } else {
    error(err.toString()); // return error to console
context.uploadContent(//FILENAME, //BASE64 string, uploadFile);
You will need to modify //FILENAME and the //BASE64.
If you need to attach the file to a thing:
context.uploadContent(//FILENAME, //BASE64 string, uploadFile, //thing to attach);
Redu.
Thank you so much yusaney1 You are my hero :t_rex:
But could you explain why I cannot add a publishState from workflow (which can show in text or input) to the database ? But It’s ok when using withtriggerEvent workflow.
In my case, When I click the Add to cart button, it returns a publishState content Image url , but I can not add it to the database in the Add to cart click event. But it ok when I create triggerEvent and create an file_uploaded event (your guide above)
Thank you
Hi there did you ever solve this? (and what is the plugin? I’m looking for a screen capture plugin that can capture images off my personal AWS s3 but none of them work (perhaps due to crossorigin security and tainted canvas. )
