I am trying to remove the two white side borders from my Bubble web app. Is this some sort of margin/padding I can disable? I want everything to extend from side to side instead of the white borders interfering with the space. Ultimately , I am just trying to remove these borders.
Presumably your page is either not responsive, or you have set a max width on the containers that contain your elements…
So check your responsive layout settings and adjust them accordingly.
