I purchased this plugin but when I add it to a pop up and centre it, it shows off to the right?
Also you don’t seem to be able to see what type of image you are choosing in the editor and have to wait to see what it looks like on the test version, this is pretty weird and time consuming when trying out different styles?
Hello, @fplassistant
Thanks for reaching us.
We suppose that the Group you have placed in your PopUp may not be correctly located. Please check if all elements are located correctly.
Also, I’m afraid that we can not reproduce or investigate this issue without more info. Can you please attach the screenshots of your current settings for this action?
As for previewing all types of Spinners before previewing the Test Page of the application, unfortunately, there is no possibility to do it.
You can see the whole list in this dropdown:
We are sorry for any inconvenience.
Regards,
Zeroqode Team
