Hi All,
I’m trying to run this maths equation in Bubble but having no luck. What’s the best way to do this?
For context, I’m building a calculator for mortgage repayment amounts.
Here’s the formula I’m trying to recreate:
Thanks
Kieran
Hi All,
Thanks
Kieran
Kieran,
You can bang your head against the wall for a bit longer and probably find a way to do this with the property editor, however a much easier approach would be to use the toolbox plugin Expression element as shown below:
I don’t know if you enabled the experimental parenthesis but I had to so I could do more complicated equations like yours. After enabling in the app settings menu it was a lot easier.
Not sure where to find this?
Hi @kieran2
You can find this in settings section “version” tab…
Thanks, this worked for me!
