Help with python integration
Hello,
I am working on an app within bubble and would like to run some python scripts (using python libraries for ML/stats, so would prefer not doing local javascript). I need run the python script on multiple items (entire lists/columns) that I have stored in bubble DB, then return multiple items to store in the bubble DB (replace/concat).
I have tried Zapier, but it looks like I can only send 1 item (row value) at a time, so it doesnt fit my use case (I need multiple items, all at once, to run my scripts). I also chatted with bubble support who recommended Blockspring, Integromat, or Parabola. Looks like Blockspring is no longer active, and am investigating the other solutions. I am open to using AWS Lambda/Sagemaker, but not sure optimal approach for this.
Anyone else figure out a solution for using python scripts on multiple items in bubble? Any help would be great! Thanks so much!
Best,
Alex
Hey! Did you get any solution for this? I’m in need too
A fast way to achieve this would be to use pythonanywhere.com together with Flask (for API’s to and from Bubble).
Asynchronously call an AWS Lambda Python from a custom Bubble plugin. The Lambda then loads and processes the data from a Bubble API webhook. Once the results are processed post them back to another Bubble API webhook. We have this architecture running stably to integrate with legacy sFTP data sources.
