Help with workflow
Hello,
I need some help, not sure if this is a bug or I am doing something wrong? probably me, but here it goes, so, I added an IMAGE and started the workflow and when I click on what to do it only says “current user” I have like 4 tables and its only picking one up and its driving me crazy, I had a similar issue but somehow it fixed itself once I removed and re-added the buttom, I also did that for the image but nothing.
You need to ‘Do a search for’ whatever ‘thing’ it is you want to change. That’s where you can select the ‘type’ of thing and then set up your search to find it.
but why it doenst just give me the options?
That’s not how it works.
