Hey i need help ...please help!
I’m currently using a template for my app.However i’d like to swap out a pluggin or two to really make my app the way i envisioned it . ( direct message if interested in helping )
@tijhonwilliams.willi you can uninstall plugins in the app you created with the template and then install more in the plugins tab.
okay i’ll try that thanks !
