Hi I am looking for help, How do I create repayment schedule
Hi I am working on loan calculator.
I need to show repayment schedule. Is there anyway using loop i can create this. or connect with excel and fetch repayment schedule and show in repeating group.
yes you can connect to spreadsheets…I know you can with google sheets, and believe excel is possible as well using plugins for it
and yes I believe you can display the information in a repeating group.
I don’t think loops are possible. I’d search the forum on the subject of loops as it has been discussed in the past.
Thanks I will try to connect using excel or google sheet will get back in case any ufrther question
