How to build Project-like memory for Claude AI?
If you’ve used Claude’s projects, you already know what I’m talking about. You can load hundreds of documents to a project and Claude can reference them in a blink of an eye. This is very different than adding text in the system prompt, as that is very token intensive.
Has anyone built memory for your claude integration? Can you teach me?
How awesome would it be if this were some sort of bubble-native feature where we can give claude or open ai access to a part of our database?
Here is a solution
That’s indeed the solution. Love the plugin. Thanks!
