How to move element to background?
Hello! Is there any way to move an element to the background? For example, if I wanted to draw a blue rectangle (shape) and then put an image and some text on top of that shape? For some reason the shape shows up on top of the image and text - possibly because the image and text are only visible under certain conditions and therefore they are not visible on page load?
Thank you so much!
Hi there, @annasnyder350… if you right click on an element, you will see a Send to back option. Want to give that a shot and see if you get the desired result?
Best…
Mike
Thank you so much! I knew I had seen that option somewhere, but could not remember where. Thanks! :slight_smile:
