How do I play a sound when conditions are met ?
Just like I am using a vibration plugin to vibrate the users phone.
Thanks
Thanks
Hi there @siddharth,
Maybe try the Howler plugin?
Can you tell me which vibration plugin you are using @siddharth
Itās device vibrate plugin from zeroqodeš¤
Thereās a plugin called āAlert soundā if I remember correctly, it works great!
