How to query the count where minus between 2 numeric fields and less than 0
Hi there
I have 2 fields called Value1 and Value2 on the datatype and they are both numeric fields.
I want to query as follow:
Select ALL records where (Value1 - Value2) < 0
Then count how many records filtered above
How do I do this?
Thanks
Hi there, @partners… you can do it with an advanced filter, but those kinds of filters are not very efficient. So, you might want to consider adding a new field to the data type that stores the difference between value 1 and value 2, and then you can do the count directly on the new field.
Hope this helps.
Best…
Mike
Thanks @mikeloc.
I was thinking to do that as per your suggestion to have field for difference between value1 and value2.
Where I can find this advanced filter again? Is this under :filter?
At the end of your search query, click (More…) and select the :filtered option. Then, add a constraint, and the Advanced… option is at the bottom of the dropdown.
Hi @mikeloc … I didn’t see the Advanced option under :filtered and contraint. Am I missing something here?
Got it. Thank you. Will explore this option further.
I’m coming from SQL database … and this type of query is a bit confusing sometimes especially for complex ones. :slight_smile: Is there any way to see this troubleshoot this query?
Hi @mikeloc
Managed to get this to work - thanks again :+1: :+1:
