I’m about to finish building my app and I learnt that the app’s width should be 380 and the height 678 ( correct me if I’m wrong because I’m not sure ), and if I’m correct then I have another problem which is : one of the groups in the app and it’s an important group, its height is around 800. and I have a bar at the bottom and this bar must be constant same as in most of the apps, so should I make the index window 800 because it’s conflicting when you preview the app or that will affect the other shorter groups and windows?
That is one of the limits of bubble, thought you could use a visible but transparent repeating group to expand the page width.
