Hey. I have built out an entire SaaS application and I am using an AgentHub API to scrape the web to find jobs for people. I am getting all the data fields for jobListing (jobPostTime, JobTitle, companyName, jobLocation and jobSalary) correctly. But I am stuck in one thing. The jobDescription field isn’t getting anything back BUT it is in the output of the automation I created in AgentHub. Is anyone able to help me? I can pay if you can solve the problem for me!!
Can you share your settings in agent hub and Bubble?
I think the underlying problem is the URLs and Descriptions that are being found in each job scrape are too long. Would this be a problem?
I spent over 8 hours trying to figure out their issue (even built them a custom plugin), and determined that it was their descriptions they are scraping that are too long, and the formatting they are outputting for the description itself. They have not paid me for my time yet. Luckily I requested a first-time deposit otherwise I would of been completely left out, but these guys are toying around.
I told them if I couldn’t figure out the issue I wouldn’t mind taking the hit, but I found the underlying issue. Once I found the issue, I relayed that to them, and as soon as I get back online, I see this post.
I get it if I don’t do anything and can’t find the problem over-all, but if the issue is out of my hands and I spend almost an entire day on your app testing things out, learning how to make things work, or making a custom plugin to filter your data more efficiently… just not how it works.
Sorry but I cant recommend these guys. Gave ample time for response.
You literally didn’t find the issue. That’s what I’ve had to do all day. Brother I have screenshots of our convo. You know what the terms were and now you’re mad.
Your descriptions are too long.
Please share them. Let people see my modesty and the communication + work I’ve done.
You are a great communicator and I can tell a very solid Bubble developer. But you didn’t complete what we discussed. You know what the terms were and even admitted to them being okay.
