My text will not move up It was perfectly fine and then it randomly went down and it will not go up no matter what I try! But inside of the editor it’s all up inside of that bar
Which text are you referring to? Is it the page title “Echo”? Or the privacy policy?
In any case, my solution is to do a hard refresh (Ctrl + Shift + R, if I’m not mistaken) on the page AND on the editor(s). There are some weirdness that happens to my editor every now and then when I’m away from it for a while.
We ended up redoing the entire thing but thank you for your help anyways @rico.trevisan
