Things will not move over
I am having problems where it says Echo bot, Prefix, and status where I cannot get it to move over although on my editor it’s completely moved over as far as I can get it but on the preview it’s moved over can anyone help also same goes for my footer
The things mentioned above need to move over to the edge of the screen or to the middle
!bump
Hey :wave:
Let’s see if I can send you some quick pieces of advice before I go to sleep. I work a lot with responsiveness. I know it’s not easy.
There are so many ways to do this. I hope this is what you are looking for.
Try to uncheck fixed width on the elements.
That would be my first guess.
Hope that helps! :blush:
@j805 www.NoCodeMinute.com
  • One-on-One Tutoring
  • eLearning Hub
  • Video Tutorials
  • No-Code Classes
None of them are fixed width
Make sure when you go under responsive you’re adjusting the positioning and margins on the elements for that screen size.
Screen Shot 2020-10-21 at 7.30.01 AM
It might be a lot quicker and easier if you share you editor link (view only access) so we can take a look at it for you. Otherwise we would just be guessing. :blush:
https://bubble.io/page?type=page&name=index&id=echobot&tab=tabs-1 @telaholcomb @J805
I haff to put the site back into action today what can I do to fix it
I also do not want all that stuff on the screen to be smaller and bunched up more together I want them to be on the edge of my screen just like they were before
It looks like you figured it out. I was just going to chime in to try to help. Let me know if it works for you now. :blush:
