I’m trying to set up the lyft API using the Bubble API connector. It uses basic auth and works in Postman, but not in Bubble.
In postman, this works:
Auth:
Headers:
Note below the body is “raw”. I think this may be part of my problem.
The curl from Lyft:
curl -X POST -H "Content-Type: application/json" \
--user "<client_id>:<client_secret>" \
-d '{"grant_type": "client_credentials", "scope": "public"}' \
'https://api.lyft.com/oauth/token'
This code that results in 200 OK from Postman:
POST /oauth/token?oauth_consumer_key=1iWFuMhFLBXb&oauth_signature_method=HMAC-SHA1&oauth_timestamp=1493140160&oauth_nonce=DwAELS&oauth_version=1.0&oauth_signature=zuU+UbOZB0ioILGVHwjfQt/48l8= HTTP/1.1
Host: api.lyft.com
Authorization: Basic MWlXRnVNaEZMQlhiOkpIbjVJZE5vTVF1Q2twcWZBTEtjdFlHc3JoTnZDanJO
Cache-Control: no-cache
Postman-Token: 2ed9de39-09f7-498b-917c-a77114f5b11e
{"grant_type": "client_credentials", "scope":"public rides.request rides.read"}
Does the code above contain everything I need for the API connector? How do I see what Bubble is passing to the lyft API?
I’ve tried every combination I can think of to make this work and keep getting this error:
Any suggestions?
Thank you for your help. You are a beautiful human being.
