I’m trying to make a invite only site where users have to enter an invite code to sign up. But I’m having trouble getting the invite codes to work. Could someone help?
Don’t run your conditional on a contains. The workflow should explicitly check against the input.
code = codeinput’s value
and take off the recursive Only when down to the first syntax of :first item
and as a good rule of thumb, you may want to sanitize the invite code that gets sent to the data base and retrieved with the syntax :uppercase or :lowercase
Take off your :first items code is codeinput’s value and just make it :count > 0
You gotta remove first item
Perfect. I’ll give it a try thank you
Yezr. Let me know
Can you also show me your privacy settings?
And explain the user experience?
Instead of a show in a workflow maybe we should make a show conditional on the element you want to show itself. I’ll give you an example
This is a conditional on the Sign Up group we want to show upon a successful invite code.
I’ve created a custom state to store the Codeinput’s value whenever the “Enter” button is pressed
I got it to work. The privacy settings were private so I made them public.
Ok. Great
Another question. How would I go about making restrictions for password? For example a password must have a minimum of 8 characters
Those settings can be found in your General settings area right up top with Privacy & Security
