Is there a way to call a Javascript function on a button click?
This seems like a pretty basic question, but I can’t see how to do it.
I just want a way to invoke a JS function (in header) when a button is clicked. Right now, I don’t see how to do that using a workflow action for the click event. I suppose I can define my own HTML button (instead of the bubble button component). But, wondering if I’m missing something.
Thanks
Srini
Check out the toolbox plugin by mishav.
Hooking up JS code
  • Install the "Toolbox" plugin, drag a button element to the page. In the workflow of that button add the newly available action "Run Javascript" and type in your Javascript. Finish with a call to "bubble_fn_a" passing your result e.g. function fred() { return "hi there fred" } bubble_fn_a(fred())
  • Drag a "JavascriptToBubble" element onto the page. Enter in the suffix "a" (or whatever) which will create the function "bubble_fn_a" being called in the previous step. Check "publish value" and set the "Value Type" to text.
  • Use a text UI element (or whatever) to visualise the result - set the text value to be "dynamic data" and refer to the JavascriptToBubble object's value
Notes
  • The button's action's Javascript contains all the substantive Javascript code.
  • The "JavascriptToBubble" element is only needed to expose the return value of your code computations to the Bubble system. The "JavascriptToBubble" element creates a javascript function that must be called by your code, passing the computation result. The name of the function is "bubble_fn_SUFFIX" where you supply the SUFFIX as anything you want when you configure the "JavascriptToBubble" element.
  • The text UI element (or whatever) can now "see" the result of the Javascript code in your button, by referring to the "JavascriptToBubble" element.
It's a bit convoluted but hopefully this helps. I'm just a beginner on Bubble so hopefully haven't misrepresented anything - Andy.
Hi, I am trying to embed this code to a button which is provided by a 3rd party service. This generates a button in html. How do I add this to a Bubble button element? I am new to programming with Bubble.
Click me to show the form!
There’s also an additional remarks from the provider:
If you would like to programmatically trigger the popup, you can do so by including the script, and calling the public function Paperform.popup(‘2q1ocwbd’); in JavaScript.
I hope you can assist me.
@abulka My JS codes have multiple functions. Should I use one suffix e.g. ‘a’ for all? Or each function has own suffix?
