Issue with Testflight Build
Has anyone else run into the issue where test users can’t download the build / app through Testflight and keep getting the error message: “The requested app is not available or doesn’t exist”
  • The build succeeded in Bubble.
  • The build is visible and has a status of Testing in Apple Connect.
  • I invited test users via Apple Connect and they accepted.
    But when the click on the app in Testflight, they get this error:
I had a similar problem - if you look at the link TestFlight generates (for public) it should not be a generic TestFlight link but rather a unique link that links to join your beta.
It’s a bug - you have to go into the web connect version and add the external group and then it seems to click for the app connect app.
