I have a list
zzz, xxx, ccc, bbbcccj
How to replace “ccc” value with “aa”?
If I use :find&replace than I would also change “bbbcccj” to “bbbaaj”
I have a list
Hi, thank you for a nice try, but I think I have a more specific use case in my app. It is very complex. I almost solved it, but I struggle with “:plus item” & “merged with”.
My RG’s source is based on 2 merged lists that are custom states:
I want to change the value in RG’s field that relates to the input with the changed value.
I try to change it by changing a list of custom state “[solution] Input add item’s l_items”.
I change it by assigning a new state:
"items until item#{Current cell’s index - 1 (index in the list of this custom state, not RG’s index)}
PLUS
(I use “:plus item” there)
“Changed input value”
PLUS
(I use “:merged with” there)
“items after #{Current cell’s index +1}”
My problem is that I get the wrong result.
For example, If I have:
“aa”
“bb”
“cc”
then instead of “aabbcc” I always get “bbcc”
I don’t know what is the root cause of this issue. I’ve already spent 6+ hours to solve this issue.
I tried to recreate this command " ‘aa’ :plus item ‘bb’ merged with ‘cc’ " on a separate page and it works. It is VERY weird.
I’ve tested it on the page with the bug, and I see that each of the 3 values is correct before merging.
Please, help!
When I put each of 3 items in custome states then it worked.
FINALLY!
Now my 2 lists in RG have a conflict.
UPDATE: fixed
