I’m trying to figure out if using a “:filter” operator after a “merge with” list on an RG datasource, will the filter be applied to the total list, or only to the list added after the “merge with”?
As i understand it probably applies it to the total which is good, but i have a situation where i want to add a :filter only to the list added after the “merge with” operator.
Example: type fruits
This RG should show only “Bananas” only from “Guatemalle” MERGED WITH “Cherry” only from “france”.
And since im not using a “do a search”, i’m rather saying: “dropdown’s” thing’s associated fruits, so i cant use “constraints” i need to use “filters” after the list.
It applies to the “list so far”.
So if you want to filter just the list to the right of a merge, you have to either move that particular search to the left, or find some other way (such as creating the list in a custom state).
What do u mean “move to the left”? I’m using the “Merged with” as an “OR” operator, if i move the second search to the left of (before) the merge, it will not function as an OR.
I’m trying to display items from 2 lists, each having their own Constraints (filter)
Not sure I follow.
Apple, Banana, Cherry MERGED WITH Apple, Date
Is Apple, Banana, Cherry, Date
as is …
Apple, Date MERGED WITH Apple, Cherry, Banana
Or am I missing something ?
no, say a type called fruits
this RG should show only Bananas only from Guatemalle MERGED WITH Cherry only from france…
Merge combines the lists and removes duplicates. It is commutative.
So what are you saying, how should i write this expression?
Cherry only from france MERGED WITH Bananas only from Guatemalle
Ah, I see, you have filters on BOTH sides !
Yes, and im not using “do a search”, im using “dropdown’s” thing’s associated fruits, so i cant use “constraints” i need to use “filters” after the list
any solution in this case?
I think custom states are the answer here. The rg would have a source that merges two custom states. Those custom states would be updated when their respective value changes.
but how do i add a constraint for a custom state list?
I was thinking you would update the entire set of values in the custom state, when the dropdown value changes. You basically do the constraint in a workflow.
But what if the list - associated to this dropdown value’s thing - changes, there is no way a custom state can update its list in real time like a RG, right?
Correct, a custom state does not update until you update it. You would need a trigger somewhere.
i guess i’ll use 2 hidden RG’s with its own filters, and reference those lists in the datasource
Is the dropdown country or fruit ?
a third type, which is the father of a list of fruits, parent-children relationship
