I recently tried to use the iframely plugin (https://bubble.io/plugin/iframely-with-unlimited-calls-1575454734851x753606218127769600) by @naj.mast. Although I am following the procedure mentioned in the demo editor, but it is not working. In fact, the html element calling this Plugin API completely vanishes when I try to use it.
Also, after using the Inspect tool in Bubble, I observed that nothing is returned from the plugin API. I have also tried to print the output as a simple text, but the text also vanished when I tried to print the output.
Is there any solution for iframely Plugin.
Best regards,
