Javascript is triggered through a workflow as it should, but it’s not getting any of the text from the input. And just to clear any confusion, I can’t use an input element for my particular case because you can only run workflows when the value is changed.
I’m sure it’s something simple. Thanks in advance.
@ada@Kayami@rpetribu Thanks for trying to help me out. I decided to take a different approach. For now at least. I’ll come back to this is if it becomes necessary.
