Rogelio
1
I have a ‘email’ and ‘password’ input field…
I would like to use the same elements to log a user in as well as sign the user up if the user is new.
so in essence, I need a workflow that needs to check is a User exists and matches the credentials provided then login, IF NOT then sign the user up.
any ideas?
Would this work for you?
Run mode: https://forum_app.bubbleapps.io/version-test/dual-login_signup
Edit: https://bubble.io/page?type=page&name=dual-login_signup&id=forum_app&tab=tabs-1
Rogelio
3
Hey @natedogg
That works! Love the humor
Thanks mate!
