Looking for a SAAS builder for my project
Im looking for a Bubble programmer to help program my next SAAS.
The setup:
The SAAS is a membership SAAS that allows my customers to create their own marketing campaign landingpages.
After they login, they can customize the landingpage trough an options flow.
when they are done the landingpage is created and can be accessed by link.
Let me know if you can help with this.
Sent a private message .
Do check
Thanks
Hi @jgravenslund,
We can absolutely help you with this. Kindly check your inbox. Thanks. :slightly_smiling_face:
I just DM’ed you a proposal :slight_smile:
Hey @jgravenslund !
I have developed similar feature to one of my clients. I have used unlayer for allowing users to build their own landing page.
