Looking for Bubble Dev for Long-Term Project
Looking for a Bubble Developer that would like to work on a long-term project. I have built apps in Bubble before and have extensive experience as a Product Manager. I am building an application for the healthcare space.
Job Description
-Database Schema and Page Structure will be provided
-Will use 3-5 API’s, including SendGrid and Stripe
-Largely a CRUD app with many Repeating Groups
-You will be able to pick your working hours
-Instructions will be provided via Loom videos (no set meetings)
Requirements
-No Agencies - this role is for a Bubble Developer looking for a long-term job
-Good English-speaker
-Must have built a reasonably complex app in Bubble before and be able to explain what you built in a Loom video
-Understand API’s
-Adequate design skills
-Maintain clear documentation in Miro
-Strong design skills
-Solid understanding of UX
-Efficient with time
Budget/Compensation
-Compensation will be milestone-based
-Milestone compensation will be calculated targeting $17 per hour to start with periodic raises
-Project to last 2,000 hours total
-Temp-to-Hire: First 90 days will be temporary employment. Long-term decision made after 90 days
Please complete a short survey using this link: https://forms.gle/9jEp26qV2sicuWg3A to apply. Thank you!
Well, at least you didn’t say Expert and Certified Bubble Developer. So that’s good. You might get someone from a country where $17 is considered a lot of money. Hope you can find someone, it’s just not likely they will have that much experience. :blush:
Could you share some details about the project? The estimated $34,000 cost ($17x2,000) might be higher than it should cost. You may find paying an expert $100-$150/hour cheaper overall as they might get it done in just 200 - 300 hours.
I am interested in the role and have the relevant skills and experience. Please let me know if we can discuss it further over a quick chat. Thanks
I am excited to apply for the Bubble Developer role. With over two years of experience in developing complex applications using Bubble, I specialize in API integrations (e.g., SendGrid, Stripe), CRUD functionalities, and designing intuitive user interfaces. Additionally, I maintain clear and organized documentation using tools such as Miro and am comfortable following project instructions through Loom videos.
I look forward to the opportunity to discuss how I can contribute to your project.
