Looking for experienced Bubble dev to help finish & polish an existing MVP
Hey everyone,
I’m looking for an experienced Bubble.io developer to help me finish and polish an MVP that’s already built (~80–90% complete).
This is an existing Bubble app — I’m not looking for a rebuild or a new tech stack. I need someone comfortable jumping into an established app, understanding the current data structure, and helping clean up logic and UX so it’s launch-ready.
What I need help with (initial scope)
Short-term, paid, and clearly defined tasks, for example:
  • Fixing / refining Repeating Group logic
  • Ensuring submitted data displays correctly (ratings, text fields, optional anonymity)
  • Calculating and displaying aggregated values (averages, counts)
  • Reviewing / tightening privacy rules
  • Light UX polish on cards and detail pages
Happy to start with a small paid test task (2–5 hours) to make sure we’re a good fit.
What I’m looking for
  • Strong Bubble experience (not learning Bubble)
  • Comfortable working in existing apps
  • Familiar with marketplace-style data, reviews, or user-generated content
  • Pragmatic, MVP-focused mindset
What I’m not looking for
  • Rebuilding from scratch
  • Switching frameworks
  • Long, vague contracts
  • Overengineering
If this sounds like a good fit, please reply or DM with:
  • A short intro
  • 1–2 Bubble apps you’ve worked on
  • Your hourly rate
Thanks — looking forward to connecting
Hey @chriscruetz :waving_hand:
Care to chat to see if we might be a good fit?
Hi @chriscruetz
I just sent you a detailed response including my calendly slot including my past projects that you can use to schedule a call with me
Hey @chriscruetz sent you a DM! :slight_smile:
