Hey Nigel, would you be able to expand on how to get this metadata containing the data centre?
Sure ![]()
You need to do a GET on https://login.mailchimp.com/oauth2/metadata
So after I do a Signup with API …
I then do an API call straight after to get the DC and save it on the User.
You get some other useful fields back that I display to the user then they connect.
Hey guys!
I would really appreciate your help! We’ve been struggling for days on setting up OAuth for Hubspot CRM. I’m sure it’s a simple config issue but we can’t see the end of it.
We followed the above instructions carefully as we were running into the same issue than @help. We’re still getting the following error :
Our OAuth workflow at the moment is the following :
The Schedule API Workflow is supposed to create an event when Signup/login with Hubspot is successful :
However, no ‘Hubspot events’ are being created, which I believe means the OAuth process isn’t working.
Here is the OAuth2 User-Agent Flow with API Connector config :
And here is the POST we’re using to retrieve the token :
When initializing the calls manually, we’re able to retrieve the authorization_code, access_token and refresh_token values correctly. However, when running it as a test-user, the error keeps popping up.
Any thoughts please @lottemint.md @NigelG @help ?
Thanks for your answer @lottemint.md!
Even without using the ‘Get Token’ POST API, we’re still getting the following error :
Any idea would be much appreciated!
Aha, you’re using the wrong link for Me request.
Try the following:
https://api.hubapi.com/integrations/v1/me
But you have a problem here.
The thing is that https://api.hubapi.com/integrations/v1/me doesn’t return user_id and email. That means, your Bubble app cannot tie a HubSpot user with the Bubble user.
In that case, you can create a manual OAuth2 flow. That provides the possibility to store tokens in your custom fields.
@lottemint.md thanks a lot for your continued help!
https://api.hubapi.com/integrations/v1/me worked and the API is correctly set up.
In your opinion can we still use User-Agent flow to enable the user to grant access, and then manually tie the Bubble user to the Hubspot user?
Or should we use a different flow for the whole process?
My thought process:
What do you think? Is that what you had in mind when you said ‘create a manual flow’?
You’re welcome!
Yup, something like that.
Note: You can escape the 2. Use GET /oauth/v1/access-tokens/:token to tie the Bubble user to the Hubspot user? step in the case if you’re building the manual flow.
You can store a received token on the User level. Don’t forget about privacy! You need to hide this field from other users.
Thanks @lottemint.md
I’ll try that asap and let you know how that goes
I’ll PM you now as well - happy to get help for other integrations
Hey @jacob,
May I know if you still have that error, please?
Reviving this old thread as I’m having a very similar issue.
This is my set-up in the API Connector:
On a page I have a button with workflow Signup/login with APi - MailChimp, but when I click it I just get the following error:
Any ideas?
Hey there @orzdirect,
Run the workflow in debugger mode on the development version
As above. Have the “signup with social” button on a page (it can just be a throwaway) and makes sure debug_mode=true is on the url.
To close the loop, I followed the guide here: [Showcase] Manual OAuth2 Token Integration and it worked flawlessly. It’s not nearly as intuitive as I would have thought!
