[Marketplace Plugin] Audio Player Plugin
@quantumind We just pushed an experimental update, please test and let us know how it goes. It was quite the work to get it working but it might be buggy as we haven’t tested on multiple devices.
It should allow you to offtrack audio
Hey. Tested it on iOS (iPhone).
Kind of works, but some things are yes not working as they should be.
  • Crossfader timer works, but the new track should start from the beginning, not from some seconds from the start. Right now beginnings of tracks are cut off. That also happens, when I just play a track, not letting it crossfade.
  • Not a bug, but would be really nice if when new track starts, “current track” and “current time” would already be new track’s, not the previous one. So the philoshophy whould be other way around - old track still playing, while we already triggered the new track. Sorry if that’s confusing, if you want, I can explain over a call…
Otherwise great progress. Thank you!
Just subscribed to your plugin with the second app of mine.
Thanks for the feedback, i’ll try to get to this asap.
Hey
Have you had any success with that?
Regards,
Vaiko
Hey.
Pinging you again with this. Did you have any success?
Regards,
Vaiko
Sending you a dm!
