Max number of options in a DropDown field
Hello!
I’ve done some hunting when it comes to how to make the list in the DropDown input bigger but can’t seem to find something relevant. Apologies if this is a duplicated post!
Issue: I am using the default dropdown input from Bubble, and I have created an Option Set named “Location” - which contains a bunch of country names. When I assign the Option Set to the dropdown everything is good, but when I preview the app the dropdown list maxes out and doesn’t let me scroll through all of the countries in the Option Set list.
I have found best results by using straight Database Things instead of Fixed Option Sets
Another thing is that you can use a dropdown plugin with search feature, would make it better for user experience and can deal with thousands of records as well, I use Selectize plugin
