Dear colleagues, please tell me what I’m doing wrong. I’m trying to give users the opportunity to unpublish, that is, temporarily hide the post, and open it again.
I made a yes/no field in the database
And changing things to yes or no. Further in the conditions I prescribed if yes it is not visible, if not it is visible. But no matter what I do, I can’t understand why there is an empty space in the repeating group.
Hi there, @vv89605501723… what you are showing is not the correct way to remove items from a repeating group. So, remove those conditions and add a constraint to the repeating group’s data source so it is only showing items where the unpublish field is no, and you should get the desired result.
Hope this helps.
Best…
Mike
God bless you sir, thank you very much. Been trying to do this for a week. I did as you wrote, everything worked out
[image]
