Multi dropdown for filtering results
I have a database of residential units. Each residential unit row in the database is described by: a Town, a Street, a Floor, a Price.
I would like a user of my website to be able to choose 3 floors (e.g. Floor1, Floor2 and Floor3) from a multi dropdown and be displayed residential units situated on Floor1, Floor2 and Floor3.
I installed Bubble’s Multi Dropdown plugin, thinking it can easily achieve what I intended.
Tried many times - it cannot be easily set up as a constraint in the form of:
Search for Properties (constraint: Floor contains Multidropdown’s value). Done this way, only Properties corresponding to one Floor is displayed even though the user have selected three Floors.
Pls help. Thank you.
Does it let you do constraint: Floor is in Multidropdown’s value
This would check if the specific Unit’s Floor (single item) is in the list of Floors (multidropdown value)
Thanks all for your quick proposed solutions. Unfortunately, they do not work.
Here are the results when I use “Constraint” based on “Contains”.
  • When I choose Storey “07 to 09”, residential units of “07 to 09” are displayed.
  • When I choose Storey “04 to 06”, residential units of “04 to 06” are displayed.
  • When I choose Storey “07 to 09” and “04 to 06”, I got an empty Table.
My setup is a Table and not a Repeating Group, I am unable to find a “is in”. Setup pics further below.
Thanks much for all your help.
