Multidropdown :group by - Does they work together?
I’m using bubble’s multidropdown but my data contains duplicates. When I set the Choices Source to Do a Search For: Group By the list of choices is perfect (no duplicates). But when I select a choice it is displayed in the multidropdown box momentarily and then it disappears. Is this a multidropdown problem or is it me?
Has anyone else got this working? Am I trying to do something multidorpdown was not intended to do @emmanuel ?
add :unique to your query to remove duplicates.
Thank you @sridharan.s - I had never seen :unique elements until right now … I feel a fool. It’s working perfectly. I appreciate the help.
We’ve all been there. That’s why the forum is so useful!
The deeper you dig yourself into the hole the less you see around you
