Need consultant help with speeding up search results (Algolia + Bubble DB)
This will be a paid job. I’m looking for someone with deep expertise in Bubble DB responsiveness + Algolia to help with search result performance issues in my app.
I’ve integrated Algolia to power my search results successfully (results are fast and accurate) but there is a common use case I’m not sure how to solve.
When I integrate the results from Algolia and filter them with data in the Bubble DB it gets slowed down a lot (unsurprisingly)
Anyone out there that I can walk through my app and help me solve the performance issue?
Hey
I’m available to help you
Hi! :waving_hand:
Not sure if this fully matches what you’re looking for, but I recently released a native Bubble plugin that handles semantic-style search directly on Bubble data — without using AI embeddings or vector databases.
It works by searching against Bubble DB types and lets you fine-tune how matching and relevance behave, which might be useful alongside (or instead of) something like Algolia depending on your needs.
You can try a live demo here:
:backhand_index_pointing_right: https://plugin-demo-38013.bubbleapps.io/smart_semantic_search_engine
And the plugin page is here:
:backhand_index_pointing_right: https://bubble.io/plugin/smart-semantic-search-engine-1762495173505x851422675193823200
If you’re interested and want to test it in your own app, feel free to share your app ID and I can enable the plugin for a week or so for you to try it out.
Hope this helps! :blush:
