I’m building a FAQ section for the bottom of my landing page and while in theory everything should work it either stops toggling after clicking it more than once or it doesn’t show the text on the first try. I’ve tried clicking Question Group to show Answer element, clicking Question Group to toggle Answer element, etc. None of them are functioning as consistently as I’d like to.
As you can see I created the following workflow for when Q1 group is clicked. It either doesn’t show text properly or it doesn’t work after first click. Alternatively, I’ve tried this workflow but that also glitches on me.
And then I repeated same workflow for the corresponding plus sign. Here is my link. https://rentmount.com/version-test?debug_mode=true
