Hi everyone, i been trying last few days to put a conditional so that when a user chooses category , if it doesn´t exists alrready as an item, it creats a new value.
heres an example i used to restric the first item, but i want to condition all items, but i can´t find a way to close the logic of it.
here´s the table category used, where i want to create each category once.
if someone could help me it will be much apreciated.
As I understand - you have a separate data type Categorys Used.
So what you can do in Only when condition is: Do a search for Categorys Used:count > 0
In your search add a constraint category = category dropdown’s value.
This way you are checking if a category you’ve chosen in the dropdown exists in your DB.
Thanks artemzheg, it worked perfectly, much apreciated your help
Heres how it turn out, the only thing we tweaked is that we made it (Categories used < 1).
